Articles, histoires, ...
Message par Freewind33 le Sam 09 Fév 2019, 07:29
"Friedlieb Ferdinand Runge, le chimiste qui a découvert la caféine grâce à Goethe", dans Le Point
https://www.lepoint.fr/histoire/friedlieb-ferdinand-runge-le-chimiste-qui-a-decouvert-la-cafeine-grace-a-goethe-08-02-2019-2292215_1615.php?fbclid=IwAR0tzByYrNegJNZCya2mzg9w4bIhGdKT1L8p2DF8dgFMuqcK8Z7dnoxpwC8
Freewind33
Freewind33
Nombre de messages : 821
Re: Articles, histoires, ...
Message par Gavroche le Sam 09 Fév 2019, 08:22
Merci Freewind... pfouh y a un nom compliqué pour dire caféine... ! juste impossible en bouche ...
Gavroche
Broyeur : deux SANTOS 6
Nombre de messages : 523
Message par Freewind33 le Sam 09 Fév 2019, 08:49
K. M. MORONEY, W. T. LEE, S. B. G. O’ BRIEN, F. SUIJVER, AND J. MARRA, "ASYMPTOTIC ANALYSIS OF THE DOMINANT MECHANISMS IN THE COFFEE EXTRACTION PROCESS", SIAM J. APPL. MATH., 76(6), pp. 2196–2217
https://epubs.siam.org/doi/pdf/10.1137/15M1036658
Freewind33
Freewind33
Message par Freewind33 le Sam 16 Fév 2019, 06:55
Alessandro Palmioli, Sara Bertuzzi, Ada De Luigi, Laura Colombo, Barbara La Ferla, Mario Salmona, Ivano De Noni, Cristina Airoldi, « bioNMR-based identification of natural anti-Aβ compounds in Peucedanum ostruthium Bioorganic Chemistry », Volume 83, 2019, pp. 76-86
résumé :
" We set up an efficient protocol for the rapid analysis of NMR spectra of green and roasted coffee extracts, enabling the automatic identification and quantification of metabolites in approximately two minutes per spectrum. This method allowed for the metabolic profiling and the subsequent evaluation of the content of bioactive compounds and antioxidant activity of coffee samples, depending on their species (Arabica and Robusta), geographical origin and extraction procedure (hydroalcoholic, espresso and moka).
The hydroalcoholic extraction is the most efficient method in terms of yields of low molecular weight compounds (in particular chlorogenic acids), while moka extraction provides the highest amounts of melanoi- dins. Moreover, that the ratio between health-giving compounds (chlorogenic acids, trigonelline and choline) and caffeine is higher in Arabica coffees.
The data collected provide useful insights for the selection of coffee raw material to be used in the preparation of coffee-based dietary supplements, nutraceuticals and functional beverages."
Freewind33
Freewind33
